Forkgram Fdroid App is not working keep crashing
I prefer F-Droid apps like forkgram instead of Telegram, but it is not working it seems.
F droid app is also crashing, and not able to update it to 2.0.1
Sorry for the trouble.I have forwarded your issue to the testing team for reproduction. If possible, please submit feedback via the PlugOS Client APP after you enter the PlugMate system. To resolve the problem quickly, kindly attach screenshots of the issue and enable logs.
After cross-verification and analysis, Forkgram V12.10.4.0 installed from F-Droid cannot run properly on PlugMate. This issue originates from the app itself. We recommend installing an older version.Update F-Droid to 2.0.1 via the F-Droid app. F-Droid 2.0.1 also works on PlugMate. As a special case: when used on PC, F-Droid may crash once on its first launch. It works normally after reopening. We will keep monitoring and optimizing this behavior.
yes on PC, F-Droid is crashing multiple times, and if we will switch the apps to see email OTP, other apps will keep restarting. sometimes i see lags.
F-Droid to 2.0.1 via the F-Droid app didn’t work for me, it was keep showing error, then i installed the f droid which downloaded from your app store, directly downloaded latest version from github. but the problem is it search engine dont work if i search goregram forkgram it keeps searching and do not show results.
Is this issue network-related? The search behavior is related to the network. To better assist you, please provide detailed error information (such as error picture) and submit feedback via PlugOS Settings → Feedback inside PlugMate.
sure will do that, it doesn’t seem to be network related, because we are using high speed wifi.
