PlugOS PC Client V1.5.8 Released for macOS
PlugOS Client V1.5.8 is now available for macOS( Apple Silicon).
Version Updates:
Added screenshot protection
Improved overall stability
Supported full-screen display
Optimized user interaction experience
Fixed various known issues
Installation & Update
  1. Download and install from our official website: Support – PlugOS Help, Guides & Troubleshooting
  2. Upgrade directly via the built-in update checker within PlugOS Client: PlugOS Client → Settings → About → Check for updates.
Minimum version requirement for automatic updates: v1.5.3
If you encounter any installation issues or need further support, please submit feedback via PlugOS client → Settings → About → Feedback,
or send an email to support@trustkernel.com.
