This release has the same set of features as the Windows version and fixes some known issues.
It is compatible with Ubuntu, Debian, Fedora and Red Hat Enterprise Linux; some older system versions are not supported.
Key Updates:
Improve app stability
Optimize network connectivity
Enhance user experience
Add support for new device models
Fix some known issues
Installation Methods:
Install via curl
curl -fsSL https://plugos.net/assets/linux-updates/install.sh | bash
Install via wget
wget -q -O- https://plugos.net/assets/linux-updates/install.sh | bash
Launch PlugOS Client:
Open the application via the desktop icon.
If the PlugOS icon does not appear on some Linux versions, run the following command in terminal: flatpak run com.trustkernel.plugos.client
If you run into installation issues or need further assistance, please submit feedback through:PlugOS Client→Settings > About > Feedback
or send an email to: support@trustkernel.com.
