PlugOS working process
PlugOS runs in an ultra-portable smart security device that connects to your phone, tablet, or computer via USB-C interface. A lightweight client APP will be installed on the host.
The entire process is like this:
  • Connect and start: Insert the PlugOS device into your Android phone, iPhone 15 (and newer models), iPad, or Windows computer.
  • Client management: Your device only needs to install one client APP. Through this client APP, you can easily manage the PlugOS device. It will present you with a virtual desktop and let you reuse the host device’s peripherals (like keyboard, screen).
  • Independent operation: PlugOS runs independently inside the device, doesn’t occupy the host device’s storage and computing resources, and data is completely encrypted and processed inside the PlugOS device. Unplug it, and PlugOS “disappears”, leaving no trace on the host.
It’s that simple, plug in and use, unplug and leave no trace!
