Protective case
Hello everyone, I have a question about the protective case that comes with the kit.
Some reviews indicate that this is not just a case that protects, but also cools the case itself.
Is it true?
It’s just that the device is getting very hot, and I’m looking for a way to cool it down.
This case does not help dissipate heat. It offers physical protection and thermal isolation. The product features a compact design built for portability and privacy. Heat must be released through the shell during high-load operation, which makes the shell hot to the touch. If your use case involves high-load tasks, fitting the protective case can help reduce the hot sensation on touch.
Understood. Thank you so much for the detailed reply.
Alternatively, enabling compatibility mode, I think, should help cool the device down a bit.
Because in this mode, the device operates at lower frequencies, as a result of which the processor should warm up less.
It’s a pity that the developers also removed all sensors from the firmware.
None of the utilities for displaying system information shows the processor temperature (aida64, devcheck, cpu-z)
But the device feels very hot to the touch, especially during heavy use.
And, unfortunately, it is not known how long it will last if it is not properly cooled …
At least, it is probably detrimental to emmc memory…
