Release of PlugClaw 1.1.8
PlugClaw 1.1.8 is now available for PlugClaw devices.
This release optimizes featured skills, adds the local token relay function, enhances host power supply compatibility, and resolves several known issues.
Update Notes:
Optimize featured skills
Add local token relay function
Improve host power supply compatibility
Fix some known issues
Learn more about PlugClaw:
PlugClaw: Your Private AI Employee That Gets Things Done | Thumb-sized AI Agent Computer)
Update Steps:
Step 1. Connect your device to a host device (such as a PC) with sufficient power supply, then boot into system.
Step 2. Open PlugOS Settings, go to System Update, check for updates, and install the available release.
If you encounter any issues during the update or require further assistance, please submit feedback via PlugOS Settings > Feedback, or send an email to: support@trustkernel.com
