PlugOS V1.7.11 is now available for all supported devices.
This is a BETA Version. please update at your own discretion according to your usage needs.
New features in this update require the latest client app to function properly. Please update your client to the newest version after completing the firmware update.
PlugOS Update Steps:
Step 1. Plug your PlugMate into the host device and boot into PlugOS.
Step 2. Open the PlugOS Settings app, navigate to System Update, then check for updates and install the available update.
If you encounter any issues during the update, or need further assistance,
please submit feedback via PlugOS Settings > Feedback, or send an email to: support@trustkernel.com
PlugOS Client Update Guide:
For Android Host Devices: V2.0.31 and above
Update or install the PlugOS app via Google Play,
or download it from:https://plugos.net/docs/index.html#download
*Users in Mainland China may download PlugOS from the Xiaomi, OPPO, vivo, or Huawei app stores.
For iOS Host Devices: V1.1.0 and above
Update or install the PlugOS app via the App Store.
For macOS \ Windows \Linux Host Devices: (macOS_V1.5.4 and above) \(Windows_x64_V1.5.5 and above)\(Linux_x64_V1.5.6 and above)
Download the client from:https://plugos.net/docs/index.html#download
If you encounter any issues during the update, or need further assistance, please submit feedback via the Feedback function of the PlugOS Client or send an email to: support@trustkernel.com
Changelogs:
Added Backup & Restore feature
Access Backup & Restore in PlugOS Settings to back up files, folders, photos, apps (app data backup is not supported in this beta version), and system preferences. Data restoration from backup files is supported.
Backups are stored with encryption, please securely store your custom password and mnemonic words to ensure recoverability.
Backup files are saved on the host device; please preserve backup data when cleaning up host storage.
Backups created on Device A can be restored to Device B with the correct password, enabling cross-device data migration. -
Added Import & Export feature
A new Transfer app is added to support importing files, folders and media files from the host, and exporting files, folders, media files and apps to the host.
Two operation modes are available: manual selection and sharing. -
Added screen rotation & tablet display mode
Optimized for large-screen display on PCs with a tablet mode, delivering an enhanced desktop experience. -
Optimized physical keyboard input
Supports physical keyboard input for the Android client; improved keyboard interaction on PCs. The on-screen keyboard is hidden by default during physical input (can be enabled manually if needed). -
Optimized Launcher compatibility
Adapted for different display sizes across PCs, smartphones and tablets to improve visual experience. -
Optimized PlugOS Settings
Improved OTA updates, network configuration, GPS settings and other core functions. -
Optimized network stability
Enhanced network reliability when a VPN is enabled on the host. -
Optimized system stability
Refined communication protocols between PlugOS and host devices; improved stability for factory reset and other system operations. -
Bug fixes:
Resolved known issues reported by users and internal testing teams.
*Beta version may cause data loss,please back up all important data on your PlugMate before updating to the beta version.
Thanks!
