Does using PlugOS leave any “digital footprint”?
I mean it real, to be invisible.
PlugOS is designed to minimize persistent and device-bound digital traces by construction.
The PlugOS device itself has no traditional physical peripherals. Display, input, camera, and network access are all provided through virtualized peripherals, implemented via controlled USB data channels. Applications running inside PlugOS only interact with these simulated peripherals and do not have direct visibility into the host device’s real hardware identifiers.
When PlugOS reuses the host’s network connectivity, it does so as a transport channel only. Apps inside PlugOS cannot access host-level device fingerprints, sensors, or identifiers through this mechanism. From the application’s perspective, it is operating inside a self-contained environment provided by PlugOS, not on the host device itself.
In normal usage scenarios, once the PlugOS device is unplugged, the entire runtime environment disappears. There is no persistent PlugOS state left running on the host, and no ongoing session that can continue to emit activity. As a result, any online presence associated with that PlugOS session effectively ends at unplug time.
That said, “digital footprint” is a broad concept. Network-layer metadata, account-based activity, and application-level behavior are separate considerations and depend on how PlugOS is used. PlugOS focuses on eliminating hardware- and device-bound traces, not on claiming absolute anonymity at all layers.
