When you need to pair your PlugMate device with a new phone or computer, follow these steps:
Preparation
Have your PlugMate device ready
Locate the product key card (QR code card included with the device)
Ensure the new device meets system requirements:
• Android phone: Android 8.0 or later• iPhone: iPhone 15 or newer models, iOS 16.6 or later
• Computer: Windows 8 or later
Pairing Steps
Install the Client
• Download and install the PlugMate client app on your new device -
Connect the Device
• Connect the PlugMate device to your new device via the USB-C port• Open the PlugMate client app
Start Pairing
• Select “Add New Device” on the app’s main screen• Choose “Pair via Product Key”
Verify Identity
• Scan the product key QR code or manually enter the key code• Complete identity verification
Finalize Setup
• Enter your original unlock password• Set a descriptive name for the new device (e.g., “Work Phone”)
• Complete the pairing process
Important Post-Pairing Actions
Verify Device List
• Navigate to “Settings” → “Device Authentication” → “Manage Host Devices”• Confirm the new device is successfully added
Clear Old Devices (if needed)
• Locate unused devices in the device list• Click “Delete” to remove its access permissions
Important Reminders
• Binding a new device does not affect data on existing devices
• If you forget your unlock password, reset it using the product key (all data will be erased)
Troubleshooting
• If connection fails, check:
• Whether the USB connection is stable
• Whether the product key was entered correctly
• Whether the new device’s system meets requirements
• If issues persist, contact customer support
Security Recommendations
• Review your device list immediately after completing setup
• Regularly clear unused device authorizations
• Store your product key in a secure location
By following these steps, you can easily pair your plugMate device with a new phone or computer and continue enjoying a secure and convenient experience.
