PlugMate is equipped with a built-in USB-C interface that supports the USB 2.0 protocol.
To use PlugMate with a USB-A port, you can do so in the following ways:
It can be used with a USB-A to USB-C adapter.
It can be connected via a docking station with a USB-C port.
If you need to connect two or more PlugMate devices to the same USB port, you must use a powered USB hub.
