I accidentally forgot the system unlock password for my PlugMate. After entering the wrong password several times, I now have to wait a long time before I can try again. Is there a way to reset this password? If I reset it, will all the photos, files, and app data saved inside be lost?
We understand the predicament you’re facing. Unfortunately, for security reasons, if you’ve forgotten your unlock password, the only solution is to perform a “factory reset.” This process requires verification using your product key (printed on the QR code card inside the packaging). For more details, please visit plugMate.net.
Reset Steps:
Connect to your plugMate device and launch the client application
Select “Factory Reset” within the client application
Scan the key to complete authentication; the system will erase data and reinitialize the device
