Navigations buttons
Hello, how do I swap the navigation buttons?
No method really works.
When trying to activate adb with the code adb shell settings put secure sysui_nav_bar “recent;home;back”, nothing changes
So far, I’m using a third-party program that draws buttons on top, but it’s a crutch.
Why was this setting removed from?
Also, there is a great lack of network monitoring in the Notification panel (incoming and outgoing traffic)
PlugOS is based on Android14 AOSP. These two behaviors you encountered are not features intentionally removed; they were never supported natively by Android14.
I understand that this is a different operating system.
But the question remains open.
Unfortunately, no way to change these buttons worked for me.
And the only option left is to write here on the forum, hoping that the developers will hear and release this along with the next update.
How are you running ADB on PlugOS?
After connecting via a PC, then as standard by opening via cmd
