Release of PlugOS 1.6.5
This update focuses on optimizing the user experience, with key enhancements including dual-folding screen adaptation, PlugOS Settings optimization, and App Store upgrades. Meanwhile, known issues have been fixed to deliver a more stable and smooth operating experience.
PlugOS 1.6.5 is now available for all supported devices.
Upgrade via the following steps:
Step 1. Insert PlugMate into the host, enter the PlugOS desktop
Step 2. Open the “PlugOS Settings” app, and go to the “System Update” section to check for and install the update.
If you encounter any issues during the upgrade or need more information, please contact us via “PlugOS Settings > Feedback” or email at support@trustkernel.com.
Changes since the 1.6.4 release:
  1. Adapted boot wizard for dual-folding screens
  2. Optimized PlugOS Settings
  3. Implemented display size/font size persistence
  4. Enhanced App Store with new categories and UI improvements
  5. Improved firewall interaction experience
  6. Fixed known bugs
Upgrade Notes:
  1. The upgrade is expected to take 30-45 minutes. Please ensure the host has sufficient remaining battery power before starting the upgrade.
  2. Upgrade files will be downloaded during the process. Please keep the PlugOS app on the desktop or enable background persistence for PlugOS to ensure the upgrade files are downloaded normally.
    (Background persistence setup guide for some Android phones: PlugOS Background Activity Settings Guide )
PlugOS service team
