Release of PlugOS 1.7.13
PlugOS 1.7.13 is now available for all supported devices.
This update adds new security features based on user feedback and fixes several known issues.
Key Updates of PlugOS:
Support compatibility mode for iOS hosts
Support client-side background audio playback
Improved launcher compatibility
Fixed known bugs
Note:The compatibility mode and background audio playback introduced in this update requires the latest Android and iOS client to function properly.
PlugOS Update Steps:
Step 1. Connect your PlugMate to a host device (such as a PC ) with sufficient power supply, then boot into PlugOS.
Step 2. Open PlugOS Settings, go to System Update, check for updates, and install the available release.
If you encounter any issues during the update or require further assistance, please submit feedback via PlugOS Settings > Feedback, or send an email to: support@trustkernel.com
