Release of PlugOS 1.7.14
PlugOS 1.7.14 is now available for all supported devices.
This update resolves several known issues and improves system stability.
Key Updates of PlugOS:
Improved system stability
Fixed some known issues
PlugOS Update Steps:
Step 1. Connect your PlugMate to a host device (such as a PC) with sufficient power supply, then boot into PlugOS.
Step 2. Open PlugOS Settings, go to System Update, check for updates, and install the available release.
If you encounter any issues during the update or require further assistance, please submit feedback via PlugOS Settings > Feedback, or send an email to: support@trustkernel.com
