Hi, I’ve noticed that some banking and password apps disallow screenshots. Does the POS client do similar? That seems like the most obvious attack vector for a compromised device.
Yes. The client includes basic countermeasures against common screen capture and input-logging techniques.
Is it possible to disable those features? I would like to see my screen / record my screen without limitations on a secure device.
You can disable this function. However, do not recommend disable it unless necessary.
Hello Jack, just got my PlugOS and was exploring around for this setting and could not find it. Could you let me know where to find it?
Thanks for the quick reply Jack. Found it and that works.
