The First Beta Release of PlugOS Client for Linux
The first Linux Beta version(x64) of the PlugOS Client is now open for testing, with basic PlugMate management functions supported.
If you wish to use PlugOS on Linux at the earliest convenience, you may join our beta program.
Currently, certain Linux distributions have compatibility issues that may cause PlugOS to crash. Ubuntu is recommended.
If you encounter installation problems or require further assistance, please submit feedback via:
PlugOS Settings > About > Feedback or send an email to support@trustkernel.com.
Important Notice
PlugMate camera access, backup & restore, file transfer, shared folders, client updates, and device-to-host clipboard synchronization are temporarily unavailable in this release. These features will be added in next update.
Install requirements and configure:
sudo apt update
sudo apt install -y flatpak xdg-desktop-portal xdg-desktop-portal-gnome gnome-software-plugin-flatpak
flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
flatpak install flathub org.gnome.Platform//49 -y
sudo groupadd -f plugdev
sudo usermod -aG plugdev $USER
sudo tee /etc/udev/rules.d/99-plugos.rules >/dev/null <<‘EOF’
SUBSYSTEM==“usb”, ATTR{idVendor}==“389c”, ATTR{idProduct}==“0010”, GROUP=“plugdev”, MODE=“0660”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“389c”, ATTR{idProduct}==“0011”, GROUP=“plugdev”, MODE=“0660”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“0e8d”, ATTR{idProduct}==“201c”, GROUP=“plugdev”, MODE=“0660”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“0e8d”, ATTR{idProduct}==“2046”, GROUP=“plugdev”, MODE=“0660”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“0e8d”, ATTR{idProduct}==“2048”, GROUP=“plugdev”, MODE=“0660”, TAG+=“uaccess”
EOF
sudo udevadm control --reload-rules
sudo udevadm trigger
Please restart for changes to take effect.
Install and run PlugOS Client:
flatpak install --user ~/XXXX/PlugOS-xxx.flatpak -y
****Replace XXXX with your local file path
flatpak run com.trustkernel.plugos.client
Download URL:https://plugos.net/static/apps/PlugOS-v1.0.0-Linux-x64-Beta.flatpak
Great job! It works well under Qubes OS with a Debian 13 AppVM. I just had to install Seahorse to set up a keyring and a password vault. After setting it as the default, I was able to register and boot the stick. Very nice!
