hi
Why does PlugMate feel hot when I am playing videos or games?
hi
hi M31M,
The electronic device may experience inadequate heat dissipation when running large applications or multiple apps simultaneously.
PlugMate features an ultra-compact design, where heat generated by the chip dissipates through the surface. For heavy-load operation, please install the Protective case before use.
1.Close large, high-load applications.
2.Close unnecessary background apps.
3.Use the device in a cool indoor environment.
4.Install the protective case to reduce the feeling of heat, and keep it out of reach of children.
5.Update the system and PlugOS app to the latest version.
