Physical Isolation for Your Data
A system built from the silicon upward, established through physical isolation and hardware-backed encryption.
Secure Enclave on Chip-Your sensitive data never touches the system.
Payment credentials and encryption keys are locked inside a dedicated hardware zone that meets CC EAL4+ security standards. Some models include an independent CC EAL6+ secure element, offering the same physical protection level as hardware crypto wallets. Even if your phone or computer is compromised, malware still can’t break into this hardware vault. -
Full-disk encryption-If the device is lost ,your data isn’t yours.
All data stored in PlugOS is encrypted at rest inside the secure hardware. Damage, loss, or physical tear-down . None of it can expose or recover your data. -
Pre-boot authentication-No one but you can unlock the device.
When plugged in, PlugOS verifies both the host device (phone or computer) and your unlock credential. If either fails, it simply won’t power on or start the system. -
Verified Boot-Built to resist firmware-level attacks.
Every startup begins with a strict integrity check. Any unauthorized change (e.g., firmware injection, low-level malware) gets instantly blocked. -
Active Data Self-Destruct-Critical secrets stay unrecoverable.
Under brute-force attempts or duress-type inputs, PlugOS can trigger an irreversible secure-erase sequence to protect your sensitive information.
