Release of PlugOS 1.7.3
This update delivers a more stable and efficient experience with optimized upgrade speed, enhanced system stability, improved host compatibility and connectivity reliability. We’ve also refined management workflows (requires PlugOS app update to the lasted version) and upgraded the user experience for built-in applications. Tool Disk has been removed, and overall system performance and reliability have been further improved.
PlugOS 1.7.3 is now available for all supported devices.
Update steps:
Step 1. Insert PlugMate into the host, enter the PlugOS
Step 2. Open the “PlugOS Settings” app, and go to the “System Update” section to check for and install the update.
If you encounter any issues during the update process or need more information, please contact us via “PlugOS Settings > Feedback” or email at support@trustkernel.com.
Changes:
  1. Optimized upgrade speed
  2. Enhanced system stability
  3. Improved host compatibility
  4. Optimized management workflows (Requires PlugOS app update)
  5. Improved connectivity reliability
  6. Enhanced user experience for Built-in applications
  7. Removed Tool Disk
Upgrade Notes:
The upgrade is expected to take 30-45 minutes. Please ensure the host has sufficient remaining battery power before starting the upgrade.
Upgrade files will be downloaded during the process. Please keep the PlugOS app on the desktop or enable background persistence for PlugOS to ensure the upgrade files are downloaded normally.
(Background persistence setup guide for some Android phones: PlugOS Background Activity Settings Guide )
Update the PlugOS Client APP at:PlugOS Client APP Release-Android(2.0.27)、iOS(1.0.9)、Windows(1.4.8)、Mac OS(1.4.8) - Release news - PlugOS Community
PlugOS service team
